ozcancak
hi yesterday ı got abs and asr lıght on my dash ı checked my car vıa vagcom and the fault code ıs thıs ...
VAG-COM Version: Release 311.2-N
Control Module Part Number: 1C0 907 379 D
Component and/or Version: ASR FRONT MK60 0103
Software Coding: 0021505
Work Shop Code: WSC 06435
1 Fault Found:
01276 - ABS Hydraulic Pump (V64)
008 - Implausible Signal - Intermittent
ı checked about thıs fault code but all similar codes has not saying 008 implausible signal .... they are like
01276 - ABS Hydraulic Pump (V64) 16-10 - Signal Outside Specifications - Intermittent
are there any diffrenences between these 2 codes shpuld i chek the pump or do you think there is an easy way to solve this problem ???
both my abs and asr is not working now ...
my car is 2001 audi a3 1.8 T
thanks for your answers ...
one of the guys at vvwortex solve the problem wıth changıng the fuse under the bonnet with the same fault code i m coruios if i can find a simple way to solve this problem without taking out the pump outside .....
Don't shoot the messenger, but most of the time with those pump codes, the faulty part is the ABS control module itself.
-Uwe-
I've the same error in my Audi A3: isn't really impossible understand which of the two to acquire..? :help:
500€ for electronic unit or 720€ for pump :cry:
Now abs doesn'work and the warning light is on.
If I reset error the light turn off, but, when I run at 25km/h light turn on again.
It was the electronic unit..., not the pump:
I solved with a new electronic unit 1J0 907 379 A.
