Inca Van info required
wingnut519
Seeing as there is no specific forum for my van I guess that's it's pretty close to an Ibiza so I've posted it in here. Hope it's all right..
I'm looking for any info on the van with regard to upgrading and modifying it.
I have a few ideas in mind, but before I go ahead and start them I want to know all the facts..
1). Engine conversion, currently it's running a 1.9sdi, I could do with a little more power so was thinking of doing an engine swap to a 130tdi lump, any ideas on whether this lump would drop straight in or not... Seen a tdi lump from a 2000-2004 Golf Mk3 that's reasonable, wondering if that would do the job or would I have to look a Ibiza lump to fit straight in.
2). Rear drum conversion.. Is it possible to convert the rear drums to discs. If so where's there best place to source the bits???
3). Lowering.. Currently she is riding a little high to say the least so I need to drop her down a little, not by much only about 30mm, but being rear axle beam and leaf springs, how do i go about this..
4). Front brakes.. With increased power I will be needing to upgrade the front discs. Seen a few threads on here talking about Mk2 G60 brakes going on, but not sure if what I read was true..
5). Finally.... Cosmetic mods... The front to me looks like a polo 4 or Ibiza, am I right in guessing this or not.... Interior wise what seats / door cards etc.. will drop straight in??
Sorry for all the question, but daring to be different, there's limited to no info on my good old van.. Oh sorry, by the way she is a V reg from 2000.
Cheers in advance for any info that you guys can supply me with.
m0rk
sarcasm comes free
27,787
33
Clanfield, UK
it's all possible :)
rear drums to discs - check the guide on the main page for info on drums to discs on a mk2 ibiza - same principle
Lowering - use blocks
Front brakes - just source the right hub carrier to allow girling brakes
cosmetics - Ibiza Mk2
Interior ie seats are the same - and door cars will be harder as they're the same as 5 door ibiza's
wingnut519
???? What.. is there someone else doing an inca conversion?????
Cheers for the info Mork.. What about the engine transplant?? Any lump to look out for?? Any to avoid??
wingnut519
Aw not fair.... You don't have to post details here, would just like a name i can contact for help and info....
JettaSyncro
IM DOING AN iNCA ASWELL , SURELY 3 PEOPLE JUSTIFIES A DEDICATED SECTION , HINT TO THE MODS , I WILL BE A CONSTANT PEST WITH REQUESTS OF HELP AND INFO
Dom16v
I'd say sort the handling out. It's no straight line warrior I know but from having fun in an empty caddy van, it's a HUGE giggle machine :D
JettaSyncro
cu51pra said:
i know someone has put a 1.8t in a inca/caddy with mk3 ibiza cupra front end and ive got the bigger brakes if you want them there the 280mm front brake setup off my ibiza cupra
Thats basically what im doing with a subtle porshe theme running through the project
