Which Induction Kit would you Recommend
  • Total voters
    28
u dont have to modify the front bumper no, i just done it for better cooling
u need to modify the horn (theirs 2, u need to move one)
and change to a smaller washer bottle (which is provided in the kit)
The RAD needs moving back slighly on brackets as the cooler if VERY deep
Hope this helps
Well changing the washer bottle would be great!!! When it's full the drivers side is lower than the passenger side!!!!! LOL.
Is it a DIY kit only or do they fit it.
And wot is the price???
That's the baby dave.
If you want to keep the honeycombe on the bottom it might require triming but this is car dependant.
price is around the £700-£750. It's not hard to fit we did it in an evening.
PM me if your interested cause i'm trying to get a numbers for a group buy for them.
For the complete kit??? I wouldn't need to buy anything else???
That won't be something i could buy tomorrow but definately the near future.
Yip, complete kit. Everything you need:
Core
Alloy pipes
Samco Joiners
Rad brackets
Jubilees
They have a stack of photo's that are helpful.
So does everyone agree that the pipercross induction kits are crap and slow you car down as thats what i have on mine at the minute ?
Yep!!!!!! Pile of sh*t. Got so much heat soak even with 2 cold air feeds!!!!
Back to standard, much better, custom cold air feed works a treat, now need to get a panel filter!!!
Problem is im running a revo stage 2 so i dont no if i can go back to the standard airbox and panel filter, does anyone no if thats possible ?
Yeah rite, i thought i'd like the dump noise but at a cruise it sounds good but to hear it every time you let off or change gear is just annoying after a while!!!!!
i do, hence why i have one of these spare
all you will need to do is smooth out the inside and get a good air feed, iv heard this gives VERY good results :)
pm sent :)
Just had a quick look over my car and as some of you no im having problems :(
the pipercross filter was covered in oil and dirt so much so i could peel it away from the filter plus the hose connected to the top of my dump valve came away in my hand as i removed it but i do no what my dump vavle is now its an old forge 006 i think :)
Sorry i thought you meant u were using the airbox!!!!!!!
I'm getting so confused today!!!!!!
I need to get hold of another airbox to smooth cos after looking at it it's not a 10 min job!!!!!
Took me about 3 hours with pliers, stanley blades and files. Nasty nasty job.
Just bought one off david :)
I have one of those little dremel's there so it should make lite work of it :)
anyone got any pics of what to remove or tips on how to get the best from it
