Titchy
515
208
Buckinghamshire
Hi all,
Quick question, I’ve been fiddling with some settings using VCDs and have just noticed that the car displayed on the screen is an FR ST however the physical car is a cupra st my18. Not sure if it was like this before or not?
Anyone else able confirm this is the same? If not would you be able to post up an admap for 5F infotaiment please or the coding for the unit, it’s the first 6 bytes that seem to make the difference.
TIA
Hi all,
TIA
Weird. I’ve got an FR SC and mine shows a 5 door Cupra haha! Not sure on how to change it.
Subject to what images the Firmware has stored you can change it. On my car you can change SC, ST or 5 door on the Golf's they seem to have more images. So yes you can change the image, Yes you can upload new images (but you need VCP for that) but stock you can only change from the list that is there.
My infotainment screen shows a silver Cupra ST, which is what I have. But have always wondered whether that was standard or is it meant to match the colour of the car haha. Interested to see responses.
so after some tinkering, i've managed to get the original cupra ST image.
It has to do with two items in the long coding. The start up screen and the car derivative.
For the car derivative you are given a list like so,
[/url]
now mine was set to the last option, ah ha i hear you say thats why i had a picture of the FR.... alas ill just change to ST Cupra, cheeky software reset and bam now its a 5 dr xcellence.... WTF?
I went through every option to no avail.
Then I remembered I had changed the start up screen (Byte 18) from the SEAT Logo and Cupra flag (BIT 2) to the copper CUPRA (BIT 7). Changed back to stock and boom it worked.
If broken down into bytes
Byte 0 Manufacturer
Value 1&2 = 04 SEAT
Byte 1
Value 1 = 7 leon, 2 ateca = Car derivative
Value 2 = 3 = mk3, car generation??
Byte 2
Value 1 = 0 normal, 8 CUPRA
Value 2 = 0 5dr, 2 2dr, 3 ST, 6 ateca
RxNb1i
