jetsetjimbo said:With the wax on was off wipe situation it's just a very thin layer required? I did my roof last night applied verticall and removed horizontally by it took a little to get it off.
I think I must have over applied.
Also tried to clay the roof. there wasn's a lot removed... Some orangey stuff - which I assume must be sap. The surface still feels quite rough but I did it all to the instructions?
One thing I did find was that some of the grabbing was caused by imperfections in the paint itself.![]()
X20HER said:I bought a clay bar off ebay last night, its a mild Sonus 100g bar for £6.49+.50 P&P which i though was quite cheap. I will be doing mine at the end of the month
fuey said:hehehe, 'Car Cleaning by FinerDetails'
dont clay after wax, cos what's the point? the contaminants are hiding under the wax.
edit: actually, im not sure if it is wrong to clay on wax....
what happened on the open day, if it's the first time your detailing, just wash the car, 2 bucket method wiv cheap shampoo, washing up liquid etc.
this should remove the wax, and stuff left over from previous noob attempts.
then the fun begins, once your back to the factory clear-coat (+contaminents), then clay to get rid of the crud.
then carry on from there, de-swirl if needed, paint cleanser, blah blah.
well, that's how i remember it.
then, for future washes, use proper shampoo, not cheap stuff that will strip away you new labour of love...![]()
FinerDetails said:Hi james,
just pure experience here mate. The roughness could still be there due to a number of things, either clay not aggresive enough, but seem to remember you are using th megs kit, so shouldn't be that, or just need more passes....
orange -prob tree sap and pollen.....stains the paintwork damn stuff
jetsetjimbo said:Cool - so if the paintwork looks ok whatever is just keep on lubing and claying -yep
Will too much lube reduce the effectiveness with the clay? - no
I assume the difficulty removing the NXT is just over application-yep, that and maybe evening condensation preventing curing.....
fuey said:Q: Am I better to lube and wax then wipe / dry with the mf and then re-lube and clay or just keep on lubing and claying?
A: just lube and clay. Wax comes after sealent.
wash > clay > de-swirl > cleanse paint > polish > seal (45min cure) > wax
fuey said:Iain, ur brains are needed
Q: just wondering about judging the effectiveness of each clay pass.
you keep claying till it stops 'grabbing at the paint'. if your really unsure, MF the area, and run your clean fingers over it, it should be 'glass smooth'.
if ur still unsure, find a spot that hasn't been clayed, or even a car down the road, and feel the paint, then feel where u have clayed, it'll be like chalk and cheese, then u'll know ur doing it right.
no real thing as curing (correct me if im wrong) when it comes to claying, cos ur just de-contaminating the paint work / clear coat.
jetsetjimbo said:I understand that - just wondering about judging the effectiveness of each clay pass.
Iain - maybe evening condensation preventing curing.....
How can I prevent that?
andyGbeatz said:all about a bit of elbow grease lads!!
andyGbeatz said:hi guys!!
quick question even if dumb sounding.. what is Clay cleaning as such? whats the purpose..
FinerDetails said:andyGbeatz said:all about a bit of elbow grease lads!!
any open day attendees like to comment here?
