Prob best to pop a jet out just to check will only take a min they just pop out with a gentle pull from the back no tools needed.
Thanks for this, eventually got round to buy a set of these and literally took less seconds to swap. :D now I will keep running out of wash trying them out.
Cheers.
Did mine last night easy change, pitty its so expensive for the heated jets.
One problem I've got is that I can't seem to get them high enough even at the max height adjustment with the torx screw it only seems to go half way up the screen. I was under the impression it should be at least 3/4 way up to allow for motorway speeds causing the water to contact the screen earlier. Anyone else get this?
Hi,
I fitted the fan washers to our Leon, fantastic upgrade - wouldn't go back!
I know this isn't the right place to ask, but does anyone know if these would fit an Ibiza Cupra, or if there is a similar mod? I haven't got the Ibiza yet, so i cannot look at the washer jets that come as standard...
Thanks,
Ben
Can I be really stupid for a moment. I've ordered a Leon without the winter pack, thus non heated washers.
I was just wondering if there was a mod I could do to change to heated ones?
Thanks!
Well I have swapped to the fans for summer, if I feel the need in winter I will swap back.
I have always wondered to be honest because I have this in my menu
I always thought it was a glitch on my software but now I know I have heated washers I am questioning if it has the auxiliary heater too!
Sent from my GT-N7100 using Tapatalk
What the s**t is this in the third row?:wtf: Was this somehow enabled through VCDS or does your car actually have Webasto? I can't find it anywhere in the Seat configurator.
Doubt it, do VAG offer a warm air recirculation feature after the engine is turned off? My Beemer has this, you can press a button on the heater controls and it will keep the blowers on and continue to circulate the warm water in the heater matrix after the ignition is turned off so the cabin continues to get warm air for 10-15 minutes after leaving it, ideal when you're only stopping for a short time before jumping back in.
