intermittent eratic idleing
jimmy2006
116
have a mk3 cupra T with a revo remap and a dumpvalve, sometimes when the car warms up the idleing sometimes will jump up and down from about 800 - 1150 rpm on tickover, I have replaced the coil packs recently, pluggs on last service, new lamdba sensor, all pipes and hoses appear to be connected with no visual leaks. Vag.com doesnt bring anything up. Just wondering if this is normal or there may be a small problem somewhere??
jimmy2006
116
yes it does, thanks. was just making sure. as soon as you press the accelerator it settles.
Jonzy
Check your aircon isnt randomly turning on, my ac just does what it wants.
cuprabaz
Racing 2020VT
Jun 22, 2004
2,357
Aberdeenshire
Try re-aligning the throttle body mate.
jimmy2006
116
just replaced the MAF sensor and its made the erratic idleing worse! anyone have any further suggestions? its got new lambda, plugs, coil packs, maf, its revo'd and runs on v power.
jimmy2006
116
seems to be the same to be honest, only seems to do it when the car has warmed up and you are sat in traffic etc or pull up to a junction then the rev's become slightly erratic jumping up and down.
jimmy2006
116
no, just lambda (another new one last week) and maf (today). I havent done an ecu reset after replacing the maf (if that might help?). all hoses appear ok also.
jimmy2006
116
coolent temp sensor, vag com isnt showing any codes regarding a poss fault with that (not sure if it would though). what makes you think it may be that?
jimmy2006
116
yeah, just read another thread with similar problems to mine. that was the temp sensor also. will have to find out what they cost. bloody sensors!
