cheers sportbillyN75 is on the intake from the Air Box
Looks like this ...
which one should i get bearing in mind that the car is revoed and where can i get one from will gsf parts have one or is it a main dealer jobby
Looks like this ...
Does any one know where the N75 valve is on a cupra might just try this and go from there.
This is a long shot and I've never actually proved it BUT I had a similar problem with my old 180bhp Cupra. Foot down and no power. This might be coincidence but at the same time I had a faulty brake pedal switch which basically meant the brake lights were on all the time.
Once I had the switch swapped out I never had the power problem again. A mechanic mate of mine said that the ECU might have though that I had pressing both the breaks and accelerator at the same time and was cutting the power.
Like I say I never proved that this was the problem or that the info I was given was right.
I can't believe symptoms like that will not turn up in VAG-COM.
Off topic, I know, but what a way to write! If I knew a lot, I couldn't help, because it's hard to read.
