Just been to my local garage. Toledo v5. Engine flush new oil and filter. New air filter. Fuel filter. Platinum spark plugs. Vehicle check. New rear beam bushes fitted. £250 parts and labour. This is a friend and i thought it was a bargain. What do you think?
OK, engine flush, oil and filter, £5 + £30 + £5.
Air filter £10.
Fuel filter £5.
Spark plugs (platinum are standard for V5). £5 each x5.
Vehicle check. It's a VAG, it doesn't need checking!
New rear beam bushes. Cheapest quote I've had is £30 for the bushes, £120 labour.
So that's £230 so far. £20 labour for the service? Yep, pretty much a bargain in my books!
I have to admit, I don't flush engines any more, especially high mileage. Things will have coked up for a reason, even if you do flush everything out you're still leaving holes where it used to be. Running the engine until it's warm and doing the oil change on a warm engine will pretty much get rid of all the loose crud, and is plenty clean enough for an engine.
