Is threre a wheel bearing replacement guide?
james walker
cooling is the key people
May 24, 2007
5,121
retford notts
hi fellas, had a search through and ive decided i need to change a wheel bearing, humming noise coming from car, had this on other cars and it has been a bearing
is there a guide on here on how to change a bearing?
is it fairly easy, dont want to pay high garage prices, fairly handy with a spanner myself.
wheres best to get a replacement bearing, gsf, seat?
cheers:rolleyes:
The MoffMeister
Half Hoff, Half Moff.
Apr 4, 2006
2,937
colchester
gsf do do them yes and pretty reasonable i have on mine and there going well considering how much stick i give it lol
you'd need a press to put the bearing in or a vice a couple bits of wood and press it in straight getting them out is bascially a hammer job if you feel comfortable doing it
just drop the wisbone so the leg hangs loose so to speak and go from there
james walker
May 24, 2007
5,121
retford notts
think i might just get the part and give to someone to do, hammer/vice bang = broken fingers for james!!
what is it a half hour job.... ish?
not sure which one is gone though, can hear the tell tale noise form the front but dont know which side?
might just replace them boh
BCM
Keyboard Gangster
Feb 1, 2005
2,680
Wishaw, North Lanarkshire
Garage will prob charge you 50 quid odds to do it, i did mine myself took it off and took it to a garage they pressed the new bearing in for a 5er and put it back on myself! Easy!
james walker
May 24, 2007
5,121
retford notts
hmmmh not a bad idea that pal.
got a cowboy ats garage round the corner theyll do that!
how does it all come off/ go back on though, no guides on here?
The MoffMeister
Apr 4, 2006
2,937
colchester
its basically drop wheel and take off disc to make life easier then undo bolt on the hub that holds the strut to the wishbone and pry it out with a crowbar or similar if i remeber rightly
james walker
May 24, 2007
5,121
retford notts
yeh okay then, that makes sod all sense to me matey.
i need pictures preferably colours and everthing.
maybe a haynes would do the trick
james walker
May 24, 2007
5,121
retford notts
sound, thanks fellas
get onto gsf tomorrow and get them ordered.
what will i need the bearing or the full kit?
anyone know the part number on gsf?
james walker
May 24, 2007
5,121
retford notts
quality link matey, looks uber complicated to me that.
may have to bite the bullet and get someone to do this for me, mite be better in the long run.
james walker
May 24, 2007
5,121
retford notts
maybe ill read it when i can keep me eyes open eh
just too change the subject, ive got another thread going, n=but i need the lower centre console part for the cupra, the plastic black bit that goes to the carpet around the gearknob bit
its scratchedto hell from passengers kicking it etc
where can i get me one of those?
neilmac
Just starting to tweak...
Jul 12, 2006
294
Out of interest what sort of noise have you got and from which wheels....?
Deleted member 28319
Wheel bearing n Hub
Just bought the same thing for my motor but was told you had to get the bearing and the Hub together, Gsf charged me £33 all in. Not having the tools, time or know how to fit myself it's currently in my local audi indy getting fitted. I've had the annoying hum for ages and was only told by same dealer when i had my car serviced a couple of weeks back what it was....
