and my knob(child)
Where did you get the gearknob from mate?
Was it easy to fit?
Cheers.
That looks nice, did you carbon vinyl it yourself? What vinyl did you use? Have tried doing my door switches and the edges look nowhere near this smooth!
yes its all my own handywork, got the vinyl from our freindly auction site, it's not the expensive stuff as i've had some shocking results with m3. as for your edge's try to degrease the bits your doing as it helps alot and once degreased dont put your fingers on it, this is the way i do it- 1 wash part in hot,hot water and washing up liquid : this will remove oil's on the surface. -2 wipe over with a lint free cloth soaked in white spirit : this will remove the fairy and leave a good surface to stick the vinyl to use heat gun to strech vinyl were needed,
allways use fresh blade to cut the stuff.
the bits ive done turned out so well that i now charge the lads at work to bits of there's.
quite the money spinner and pays for other mods![]()
