julioracing
75
my car was a TDI, I am now transforming 20VT. I often go to the circuit, and my car was too small. Here I leave some photos that you may see the process.
Tdi transmission will work as it is an o2a box, the only problem might be the ratios being a bit long. But that depends on your driving preferences and driving style. But having the hyrdaulic clutch as standard means you can easily swap in a box from another car.
hello, also the box is mounted 20VT, 02R but the differential is the 02J, you may ride the Quaife limited slip differential that I have mounted on the TDI
the TDI engine - AHU 90cv. Powered with 140hp and 320nm. with the help of an IHI turbo 4x4 OPEL Monterrey, 110 hp injectors, etc
[/URL][/IMG]
admission and exhaust audi a4 130cv, exhaust 60mm. diameter ,differential QUAIFE, sachs kit clutch, Brembo brake,....
