Juilios 20vt Cordoba
julioracing
75
my car was a TDI, I am now transforming 20VT. I often go to the circuit, and my car was too small. Here I leave some photos that you may see the process.
M1KEH
M1KE
Oct 27, 2007
2,336
The Middle
Tdi transmission will work as it is an o2a box, the only problem might be the ratios being a bit long. But that depends on your driving preferences and driving style. But having the hyrdaulic clutch as standard means you can easily swap in a box from another car.
julioracing
75
hello, also the box is mounted 20VT, 02R but the differential is the 02J, you may ride the Quaife limited slip differential that I have mounted on the TDI
julioracing
75
julioracing
75
the TDI engine - AHU 90cv. Powered with 140hp and 320nm. with the help of an IHI turbo 4x4 OPEL Monterrey, 110 hp injectors, etc
[/URL][/IMG]
julioracing
75
admission and exhaust audi a4 130cv, exhaust 60mm. diameter ,differential QUAIFE, sachs kit clutch, Brembo brake,....
