Just about to fit my ForgeTIP...
Dougy
Ibiza Cupra R
Dec 10, 2008
238
Yorkshire
Struggling to get the standard pipe off the metal bit just seems no room to get it out!!
Am i missing something i have undone the allen key bolt just seems like no room to twist it out
Dougy
Ibiza Cupra R
Dec 10, 2008
238
Yorkshire
its that bloody bottom hose thats stopping it how the hell do you get that off
ARRRGGGHH Nicotine break!!
TJenkos
213
Derby
I didn't trim any, its OK getting it on.. Its doing the jubilee clip up without slipping it back off thats the pig!
Dougy
Ibiza Cupra R
Dec 10, 2008
238
Yorkshire
well got it on eventually, now i can't get that stupid pipe over the metal nipple sleeve on the TIP WTF!!
Dougy
Ibiza Cupra R
Dec 10, 2008
238
Yorkshire
Am i missing something here cos that pipe ain't going on the nipple just can't get enough on it to push it on
Dougy
Ibiza Cupra R
Dec 10, 2008
238
Yorkshire
Its the metal nipple that sticks out on the Forge TIP near to the turbo
I can't get the pipe to push onto it
Dougy
Ibiza Cupra R
Dec 10, 2008
238
Yorkshire
how do I block off the metal bit its part of the TIP!!
Just so were sure this is my problem
Dougy
Ibiza Cupra R
Dec 10, 2008
238
Yorkshire
Well the washing up liquid worked too well as the metal bit came out completley.
Which in a way made it easier to push into that pipe but still not a long way in, just hope it sucks
Now to get some glue to hold it all in place unless you think it will be okay? its a tight fit can't see it moving
Dougy
Ibiza Cupra R
Dec 10, 2008
238
Yorkshire
Right guys fitted tip couldn't really tell difference as car down on boost anyway
So whilst looking around i spotted 2 broken vac pipes so replaced them and moved my boost gauge "T" to the brake servo.
Now as its due in the garage tomorrow i thought i best VAG com it for faults and look at this what came up...
Address 01: Engine
Controller: 6K0 906 032 AB
Component: 1.8L20VTCUPRA R 0001
Coding: 11500
Shop #: WSC 00000
1 Fault Found:
16795 - Secondary Air Injection System: Incorrect Flow Detected
P0411 - 35-00 - -
Readiness: 0000 0000
Could the TIP cause this?
Jan 8, 2007
2,958
Wiltshire
What vac lines did you replace? Have you bypassed the N112 and N249 valves?
It may be an old code that was thrown due to the split lines. Shame VAG COM doesn't timestamp fault codes.
Clear the code, ensure all lines are connected properly and keep an eye to see if it comes back.
