K03s installation (Price)
__B3NNY__
OEM with a 'Twist'
May 5, 2005
3,449
Oxford
Picked up my K03s wednesday looking to get it fitted in the next couple of weeks. Im gunna havea little look around this afternoon and make a few phonecalls, but was just wondering what sort of range i should be looking at price wise to pay? Or if theres anybody on here that is competent at doing the swap over and would like to earn a few tokens? Im based in oxford but dont mind travling abit to get the work done. Id supply the kit and some oil.
Also is there anything else i need to get bar the fitting kit, oil, and maybe some coolent?
Cheers David.
__B3NNY__
OEM with a 'Twist'
May 5, 2005
3,449
Oxford
So going by the average (average being £50 P/H)rate ill be looking at about £200 tops.
Cheers.
__B3NNY__
OEM with a 'Twist'
May 5, 2005
3,449
Oxford
All sorted now just been down to see a bloke thats got his own garage and its going to be fitted in 2 weeks time im going to supply the kit oil and coolent and hes going to fit it for £100 :D.
Cheers lads.
Black TDI Turbo
Shussssh Its A Diesel ...
Oct 2, 2005
1,175
North East
make sure you use new crush washers on the oil and coolant pipes and also all new gaskets, dont forget the two gaskets needed for the oil return pipe aswell.
__B3NNY__
OEM with a 'Twist'
May 5, 2005
3,449
Oxford
Im gunna get what the fitting kit lists in the sticky section plus oil and coolent. Is there anything else or is all in the list?
Cheers.
__B3NNY__
OEM with a 'Twist'
May 5, 2005
3,449
Oxford
Cheers Olly, Do you have a part number to add to the list as im a little unsure what gasket you mean. So oil gasket, oil, coolent, and the K03s fitting kit and thats it? Is it worth buying 5ltrs of oil or will a small bottle be enough?
David.
Olly20VT
1,234
Stroud Glos ,England
I can't remember what it is justask the dealer, i think its the same as the other oil one tha is in the kit, i did an oil change at the same time so 5L should be ok them top it up later.
