mikey_b
322
Manchester
Hi folks i just got my hands on on K04 turbo (17,000 miles) im intrested in getting it hybrided...as im in manchester wheres the best place to get it done???
I also got a manifold (ported), injectors and 4bar fpr. Just need to get hold of a downpipe is there anythink else i need? (beside urated brakes!)
CRturbos
Turbo Dynamics.
Speak to them both and get the best deal. Both reputable and know the K04 well. Approx £500.:)
K04-23 on a K03 car? Going to need to look at the charge pipe routing and the intake. Might need a LCR/TT225/S3 MAF. Probably need new lines.
Need to talk to a mapper about MAF and Injectors. Your sig says twin pass FMIC - you might stuggle with that, inlet and outlet on boths sides?
Unless you meant a K03s hybrided with a k04?
im gunna get custom pipes made and yeah the inlet and outlet are on the same side! ive got a lcr maf coming...ive got injectors off a S3 and so is the turbo!!
Whats the best size pipes to use for the intercooler?
You need a different manifold and downpipe, CAT's etc. as well. Yeah CR Turbos, Turbo Dynamics and also AET Turbos all do hybrid work although personally I'd go with CR Turbos.
yeah i got a manifold off a lcr witch has been ported
