Feb 22, 2009
3,459
South Wales
dog has chewed the cable going from microphone to bt unit tried to repair but no joy
ebay replacements are OTT @ 27.99
http://cgi.ebay.co.uk/Kenwood-Mic-B...S_In_Car_Audio_Players_PP?hash=item2ea9a92848
anyone know if anything from maplins or similar will work?
I have tried searching web but cannot find specs anywhere for the microphone failed to even get a part number
Go into maplins and buy some cable connectors of your choice, and then cut just before and after the chew, strip the cable sheath back and then join them back together using the connector. You should have plenty of slack in the cable to do this.
yep they do.any mic with a jack plug the same size will work,might not be as good quality depending upon which you buy but will be minimal
thanks mt audio - other halfs car is a mk4 golf - same interior light fitting as the leon
next to the drivers side map light switch is a vent was hoping to fit a microphone behind this would this work?
