keskin kt1's FITTED
L9 GOW
117
perth scotland
what are peoples thoughts on these?
just bought a set, 16" 9" wide.
polished dish with black center?
they are for my ovni yellow ibiza.
still undecided if i like them or not.
stebbi
Got Boost???
Jun 10, 2008
270
Preston
if you/ve bought them just try them on.
i was going to get some for my ibiza but the wheel money has gone on a gearbox rebuild :)
Dec 13, 2006
724
Ashford, Middx
what should i be running?
would i need spacers?
is it for looks or will they not clear the brakes?
Standard offset is et37 i think.
Spacers will bring the offset down even lower so would make them less likely to fit.
What brakes have you got? You may need to find out the caliper clearence on the rim.
beattie17
1,353
Perth
They will clear your brakes, they're just going to sit out really far on front. Buy a set of et25's for front
L9 GOW
117
perth scotland
trial fitted them today!
still not sure weather i like them or not!
comments welcome good or bad!
before
after
gezmeister
I need a derv!!
Apr 1, 2008
2,172
Norwich
Thanks for the good comments peeps!
just let off the jack and also it wasnt sitting on the flat.
but your right the rear does have to come up a bit:(
maybe bring the front down a bit too:)
The front looks spot on mate, i wouldn't touch it if it were me, just try to match the rear to the front as best i could :)
How much did you pay if you don't mind me asking?
beattie17
1,353
Perth
Looks good. Raise rear a little fit 5mm spacers and lower front a wee bit, should look spot on, and then better pic's, get it done
