what should i be running?
would i need spacers?
is it for looks or will they not clear the brakes?
if you/ve bought them just try them on.
i was going to get some for my ibiza but the wheel money has gone on a gearbox rebuild![]()
Standard offset is et37 i think.
Spacers will bring the offset down even lower so would make them less likely to fit.
What brakes have you got? You may need to find out the caliper clearence on the rim.
They will clear your brakes, they're just going to sit out really far on front. Buy a set of et25's for front
i think they look awsome heres mine on 9s on the rear 7.7s on the front
http://www.seatcupra.net/forums/showthread.php?t=129728&page=5
Looks good, but i'd personally raise the rear up a bit, looks much lower than the front
Thanks for the good comments peeps!
just let off the jack and also it wasnt sitting on the flat.
but your right the rear does have to come up a bit
maybe bring the front down a bit too![]()
