Key battery warning
andrew_ww
130
Hi,
Got a warning to change the battery in my key today, I assume this is a diy job and not a dealer activity?
chrisRibiza
1,194
51
Yep very simple.
The battery cover just pulls off the key then you can take the battery out. Can’t remember off hand which battery you need but it’s easy to check your key.
SRGTD
2,420
1,300
Really easy to do. YouTube video showing you how to do it;
https://m.youtube.com/watch?v=va8mJhsfeGA
The guy on the video says it’s difficult to remove the battery cover on the key fob. It wasn’t difficult on mine - I used a 50p piece to remove the cover - put the edge of the coin in the slot where the key blade folds into and just twisted it and the cover popped off.
EFF11
138
38
The battery is a 2025. With these batteries 20 is the diameter (20mm) and 25 is the thickness (2.5mm). It's important to buy a reputable brand from a reputable source.
stevemc81
144
15
I did this the other week. Used a knife to wedge open the fob. It was a bit tight and it felt like I was about to break something but then it just popped off. I got a couple of Duracells from Argos for £4.
Andy1977
92
18
I changed the battery on mine a few weeks ago, every now and then I still get the change battery warning. It even stopped working until i took out the battery and put it back in. It was an RS battery I got from the maintenance guys at work. I should probably go buy a reputable battery from the shop and change it again.
BoomerBoom
702
253
You have to replace the battery and it will go away. If you still have the warning then the new battery you've used isn't any good.
Reactions: Mr Pig
Tha_Matt_Man
28
14
Belgium
Small "hack", the battery is the CR2025 but you can fit a 2032.
The 2032 is only thicker (higher capacity) but you can fit it in. If the battery jumps out, use something to keep it pushed down and click the cover back on it.
BoomerBoom
702
253
It doesn't matter what the battery checker says, mine also had the right voltage but the key still didn't like it. The 2032 battery trick solved the problem, as it has nearly double the capacity of the 2025 and a much longer shelf life.
davelee
19
Contacted Unicars told to buy special tool have to travel 80k to do this then they tell me they will not tell me the battery number not nice also charge €20 per litre thats €110 for 5.5 ltrs disgusting.
davelee
19
2025 is what is in there when removed pop's out 2032 will stick out need lid to push in
Sean Ryan
16
Anyone else had this issue. both keys came up the warning within 2 months of each other. replaced both batteries with decent energizer ones. Warning still there for both keys.
I kept using the main key until the battery died and couldn't unlock the car, since replacing the key works fine now but warning is still there.
