I've recently bought an '02 Leon Cupra, which I'm still getting to know (first VAG car).
I seem to have a
problem with the central locking and alarm. First of all, the passenger door is playing up and VCDS-lite says there's an intermittent
problem with it. Occasionally the door will work properly, the clear/red light and the main courtesy light will come on, but other times it won't. Also, I haven't had any issues with it locking/unlocking via buttons yet.
I think this door may have a lot to do with everything else.
For the first time, the alarm has gone off randomly, after hours without use, with no sign of disturbance inside or out. I think this is the faulty passenger door with a poor connection telling the car that it's suddenly open. This door doesn't get used much, but did a few times on this day.
I've read many times about the key having a double click feature, but I've never got this to work. I bought the car with it set to only open the drivers door, but I could never open the other doors with the fob, only by the button inside. I've put the setting back to normal (00259), resulting in all doors opening with one click. I don't have the flip key, and it has two buttons. I've read the manual, which does NOT mention being able to open drivers door with one click and other doors with two clicks. The only double click feature is for locking, which on the second click disables the alarm... which also doesn't seem to work - could this also be the faulty door? I think there might be a few Leon's with keys that do different things.
I have tried double clicking many times to see if I can disable the alarm with it locked, but no joy. I've tried pressing it at different speeds and used the same method in the door lock, but that little red light on the door keeps flashing away. Apparently the red light stops flashing if the alarm is disabled.
I'm not sure the volumetric sensors work - I've sat in the car with it locked for over 30sec looking special, and nothing. It has that button down near the seat, which I don't have a clue if it works because I can't test the sensors. Also, the vag-com says the sensor is on, no faults - but is it activated, does the car think the passenger door is open?
I want to strip all the doors down and reseal them, as well as fixing the passenger door, but not in this cold weather. On the other hand, I don't want the alarm to start randomly going off. I may have to take #14 fuse out for the winter.
