Key ???
tubbsy
hello there every one just got my self a seat ibiza mk4 1.4 sport had a bump at the front so gotta get that sorted and all i was given 1 and a half of a key lol 1 key wiv out the 2 buttons just a key to open the door and the one with the 2buttons just that wiv no key on it !!!
i want to buy the flip key but dnt no witch one 2 get can any 1 help me with that ???
thanks
great_kahn
Spooge
Nov 19, 2009
2,415
Leicestershire
thanks
There is a simply epic thread on this in the FAQ section. Should give you all the info you need.
Mar 25, 2009
1,245
bath
Any key cutters can do it I thought, I got mine done at a shoe repair type place, and it's the best mod ever!! X
tubbsy
soo if i buy a 2 button flip key off ebay and get the key cut should that just work then after programed it to the car or do i need to take anythink out the other keys ???
g60jonny
Right then....just to sort a few things out here!
I have just bought one of the keys from fleece bay and had no trouble getting it cut, it came with a blank uncut blade and a local locksmith cut it for me for £3 :funk:
The mainstream key cutting places are scared of damaging the electronics side of things, but if they know what they are doing then this won't cause an issue!
The ebay key will have the remote capability that you can 'pair' with you car, the problem comes with the transponder in it. This too will be blank and un-programmed but you will have to go to a main stealer to get it programmed:(
Alternatively, you can do what I did (which has been done by many before) and carry out the following:
Remove the transponder from the new key and keep it somewhere safe for use in the future perhaps.
Then get your valet key ( the one without any buttons) and split the black plastic section in half.
Then take a stanley knife or similar and VERY carefully cut away the plastic that secures the transponder in the fob. Take you time doing this as the transponders are fragile and if you damage it, you're back to square one!!
Once you have removed the transponder from the valet key, fit it to the new flip key and then follow the steps for programming the remote to your vehicle.....simples! [B)]
Hope this helps?
G60
SWANSWAY CUPRA Dealership
