Keys
Wobbly
hello
i am looking to change my key to a flip key, i see there are the standard units on ebay, but im not a hundred percent sure if they are the right ones. also they need programming as i understand, is this an expensive job? and how do i go about it??
Wobbly
bruceR
2,578
665
Monifieth, Dundee
Go for it mate, I done this 4 years ago and programmed it as per the owners manual - so easy, plus the range of the flip key is 10x better than the original key :D
Wobbly
yeah i wanna get it done, did you buy your key for ebay??? was it hard finding somebody to cut the key??
bruceR
2,578
665
Monifieth, Dundee
Yeah I got mine off ebay, think I paid 10quid and got it cut at Timpsons :D
Put the transponder (glass tube) from my old key into the new one and used the red key to programme the new one. All worked fine once I realised I had to keep the drivers window open during the programming!!!!
Wobbly
now in the process of finding a key on ebay!!!!! i dont have a red key with mine, i have one key with two buttons on and another key with no buttons on!!! will rember the window!!!!!
Wobbly
i think i am missing something here!!!! the only flip keys i find are 35-45 pounds???? any ideas???:(
Muttley
Catch that diesel!
Mar 17, 2006
4,987
31
North Kent
clackie wrote
yes it will mate but that is just a case so u will need the transponder to operate the remote locking
Not the remote locking, you'd need a flip key with the separate radio transmitter for that.
The transponder is a passive device (no battery) that is interrogated by the immobiliser reading coil that surrounds the ignition lock. Without a matched transponder the car will start then cut out immediately and the immobiliser light on the warning panel will light up.
Wobbly
ok thanks for your help chaps, i think i will also need the remote section??? 433mhz i think???
