KO4 Turbo!!
cuprachrissy
Hello peeps, on ebay just found a KO4 turbo with all the bits, MAF, oil feeds etc. Has anyone got a KO4 on there MK3 Ibiza cupra?? if so is it worth the 250-300 quid mark?? 40k miles done on it.??:confused: need to kno asap as it is finishing in about 45 mins!!!!
cuprachrissy
it does come with maf etc, do a lot of people put k04's on there cupras cos it seems a lot of them have k03s'?
cordobabrendy
FOOORRREEE!
Aug 24, 2001
7,642
belfast
In case theres confusion here chrissy, the maf is a sensor , the manifold is a totally seperate and expensive part if upgrading.
cuprachrissy
cheers mate!!kinda new to this scene! wat do you think about this turbo then? too much hassle??
mk1golf_jack
Golf nut
Mar 13, 2007
80
Herts
Hi, Just done this conversion, you need maf tube, forge tip for LCR/s3, all oil and water lines for k04 (even then they need modifying , custom dp, k04 exhaust mani, matching injectors from k04 car, its alot of trial and error really when fitting but k03s is much easier by far, ive yet to get mine mapped as i just finished putting it all together but its lookin good, hope this helps, Jack
h17och
the hunt is over. 460bhp
Sep 1, 2005
3,504
Dunstabubble
if you aint clued up dont do it! ive help jack a little with his. certainly not as easy as your thinking but doable if you like a challenge
