Alas I have done all of that and still nothing.
Just tried again, setting back to GB removes the alternate speed option, setting to ROW shows this and sets distance units to KM (temperature remains in C).
Still nothing though.
Guess my car may be different, it won't let me make the door lock beep either.
Glad my cable did needle sweep at least.
Shame..Maybe it is..you need another Supercopa owner to try it..
Needle sweep is cool but you're not missing much with the locking/unlocking beep...turned mine off after a few weeks as it was loud and getting on my tits..(and probably the neighbours at 6 in the morning..!)
Just because they share a chassis and engine etc doesn't mean everything is the same
MFD in pre-facelift cant display speed.
Just want to check, if you enable the large MPH display, you lose the kph altogether? Or is there a way to change it back without VAGCOM.
E.g. Come MOT time can I go into the MFD options and change the units back to KPH or would I need VAGCOM?
After its done you can switch it back on the settings in the mfd
Any idea why my number is absolutely massive and the other screens go slightly off centre?
