LCR actuator pipe split
Jamie225
322
Leicester
Thort my LCR has lacked a bit of power recently, checked it over briefly last week and could see a massive split in the vacuum pipe the goes directly onto the actuator on the turbo. My question is does anyone know the thickness of the pipe so i can make my own to fit?
Thanks in advance
Ronin225
4,652
22
Worcester
N75 to actuator has different i/d sizes either end
At N75 end 8mm is ideal but onto actuator will require a reducer to about 5mm to fit the nipple
Ronin225
4,652
22
Worcester
Most people will not have changed this one but i've had it off to look at it before.
Pipe retains same o/d through out but i/d goes down, no one seems to know why either
Also the 8mm pipe is way to slack on the actuator in case you try
Ronin225
4,652
22
Worcester
Not quite sure how you got that on to the N75 then, unless you're thinking of the other vac lines that are 4mm
