Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Guest, 🎅🎄Looking for a stocking filler idea? Why not treat yourself or a loved one to our high quality CUPRA or SEAT valve caps.
Have seen just over 200g/s, average is as Si said 195ish
MAF quite often fails by under reading rather than going completely dead, any chance you can borrow one from a mate? if not GSF have them on exchange for crica £85 ish
i have 2 actually funnily enough after a mate descreened my orginal then i had all the boost problems so i replaced the maf then but kept the descreened one perhaps i should try putting that back on
Also, idle readings aren't very meaningful so if you are unsure always do a ful throttle run. Besides that, make sure you've got a solid reading without jumps and such thing - to achieve this make sure to have a high sample rate while logging.
my car never actually sat at idle it fluctuated between 2.56g/s and 2.86g/s and on the odd occasion it hit 3.1g/s the rpm never sat still for more than couple of seconds it was just bouncing between 720rpm and 760rpm. This was all at idle never touched the peddle once
Mine reads anywhere between 2.6 and 3.1 but it idles at 720rpm constant.
As for peak flow, Mines APR'd not Revo, but it peaks at 190g/s with the dynatwist on and gives similar figures with the standard airbox although not as strong throughout
