Lcr brake dics
ibizacupra
Jack-RIP my little Friend
Jul 25, 2001
31,333
19
glos.uk
£115+vat each. plus carriage (£20)
2 piece disks were 330x28 size, AP Racing disks
330x28 Ap Racing Disks, 8 groove, Blue Anodised Bells, mounting bolts kits, caliper spacer shims
£650inc vat Pair
plus delivery
Replacement Disk Rotors £221+vat each
vern
I Miss Her Below!
Jun 17, 2003
2,020
N.Yorks.
seatcupra.net
Si said:
I've been looking for aftermarket disc's but can't find any except Bill's or standard from Seat. But i'm not a fan of Bill's (ATE Power) groove design. :cry:
They work well si, is it just the pattern you dont like? it's got another function, iirc, Billl will correct if i am wrong, once the pattern fades disc is @ Min thickness, very easy to see then, even when walking past :)
neil_f225
521
will the ap ones last a lot longer and be better on track. One day at the ring and the discs are f****d! Brakes are very poor from above 70mph now and there is a really loud droning noise from them - no vibration though? I am running ds2500 pads - would these still be ok on the ap's
ibizacupra
Jul 25, 2001
31,333
19
glos.uk
cooked fluid and glazed pads perhaps... ALL brakes worked hard will drone. its the way things get when they're >600'c hot.
DS2500's are fine on AP's and other disks.
Got decent brake fluid in there?
Remember how heavy a LCR is.... not even 323 brembo's can shed all the heatload.
ibizacupra
Jul 25, 2001
31,333
19
glos.uk
neil_f225 said:
still running oe fluid. Are you running the aps on the beeza?
Consider Motul RBF600 as your next brake fluid.. Very high temp fluid. What I run in my ibiza and cured my boiling brakes.
I run AP's yes... at the moment.
