747_727
1,113
Essex
My car had a misfire this morning so I checked vag-com and found fault code 16395
Rosstech said it could be the Camshaft Adjustment Valve 1 (N205) being faulty
Is this the cam chain tensioner? I didnt know these had a chain which links up the 2 cams untill today?
I also have had a small rattle on start up since I bought the car and it mainly does it when the weather is cold Im now thinking it could be the tensioner!!
Video here is may car last winter
http://youtu.be/kNDalQ9B9l4
Any ideas on what it could be?
Camshaft sensor in the side of your engine 5min fix mate, cost £35 for the part I think
Possible Causes
Camshaft Adjustment Valve 1 (N205) faulty
Fuel Pump Relay (J17) faulty
Mechanical Timing not correct, including Chain and/or Belt timing.
Possible Solutions
Check Camshaft Adjustment Valve 1 (N205)
Check Fuel Pump Relay (J17)
Check Mechanical Timing
( stolen from another site, Google is useful you know..)
If you've got yourself a cold start up rattle, then it would suggest lack of tension on the chain. I'd look to replace the whole tensioner unit.
Trust me, I know, I've also pulled the same code today! Along with...
17536, 17511, 16514, 17956, 16684 and 16687.
Basically, I need a new lambda and a new vvt tensioner
I've just changed my mates B1 S1 today came of in a sec was panicking it maybe stuck with the heat, also fixed his sticky calipers, massive difference once you change those lambdas,
