any of you guys with leon upgraded your front wishbone bushes? if so what you gone for?
You've pretty much got two choices, SuperPro or Powerflex if you have an LC. If you have an LCR, you have these two or also the option to go for a solid rubber bush from the Audi TT roadster.
Any extra vibration?
Oh really? I thought they were different bushes as the LC uses a pressed arm while LCR is a cast arm?
Have set of powerflex bushes in a spare set of wishbones waiting to go on
Having rebushed a few LCR wishbones with OE and poly, i can definitely saying poly are much firmer and stronger and a tighter more supportive fit.
Also all pics taken so rebushing guide will be made soon
i've got phil's old ones, can say the tt bushes far outperform standard ones
i did phill's new ones, my trial run so to speak
so the tt one's fit the lc front wishbone, front bush. is there any oem upgrade,s for the front wishbone rear bush?
anyone using the superpro ones? heard there not as harsh as the powerflex?
No the TT one goes at the back, only one for the LC front bush i have seen is the polly one.
