gae1431
All,
After some advise if possible please. Recently changed my LCR 18" standard alloys for a set of 19" Dotz Roadsters but to fit these, and the size of the calipers i had to buy 10mm machined hubcentric spacers highly recommended by R Tec off M25 north.
Anyway i am due to change my disc and pads and was wondering if this will effect the position of my Brembo caliper and push it out towards my new alloys even more, as currently have approx 3mm clearance between the outer face of the caliper and the inner of the new alloys :confused:
Was wondering if anyone new if changing the pads and discs for the same standard disc and pads would this push out caliper or not due to the extra thickness on the pad! SOme people have said yes and some no, but i guess it depends on a few things.
Possibly a tough one as i have just spent £1000+ on new alloys. If it does interfear with alloy i will have to look at getting new spacers i guess.
Help please if poss :D
Thanks Probee,
I wasn't sure if the caliper was floating or not or if the movement was inside the caliper only and the caliper remained fixed.
Now my worries are gone away:)
Thanks for your guidance and help.:funk:
