LCR strut removal
lcrsammy
135
berks
hi all, im hoping some home mechanics could offer some advice.
ive been reading the online manual for the s3 about strut removal and it says you need to unbolt the right hand drive shaft from the gearbox flange to do that side.
can you remove the strut whithout doin this or not?
Sent from my GT-I9300 using Tapatalk 2
285cupra-matty
488
Harlow
I take it you mean suspension strut, if so I changed mine and can confirm you dont need to remove drive shaft to take it off.
lcrsammy
135
berks
yeah should have been more specific lol
yeah suspension strut!
thanks matey
BigJase88
Jase
Apr 20, 2008
3,767
1,069
Nope no ball joints need split and no driveshafts need removed
All you need to split is the hub... Which isnt too hard!
Springs will need compressed to remove strut and a bit of brute force will get the shock out
lcrsammy
135
berks
do you mean the pinch bolt on the rear of the hub?
thanks for all the input guys! just trying to make sure I know whats ahead of me before I try this!
BigJase88
Jase
Apr 20, 2008
3,767
1,069
Yes take pinch bolt out at back of hub. They you have to try and spread it open to let the shock slip out!
I found the cheapest way was an old 8mm allen key ground down on 2 opposite faces (so that it fits into gap) then when you turn the allen key 90 degrees it should split the hub for you
Poor explanation but hope you get it :O
