Just to confirm, if the big fan comes on fast and the little fan never comes on, does all this still apply ?
Guest, 🚨New Stock alert: Premium CUPRA valve caps now available in the store 👉 Order now from the merchandise store
When the fan kicks in and the lights dim slightly, if I also have my headlights on (air con on obviously) the window switch control lights start flashing on and off manically, until the fan shuts off again. However, if I boost the revs to over 1k the flashing spasticated lights stop.
I'm assuming that that's the battery not able to cope or something...
I'm now slow again!!!
On the last day of my warranty I decided to edge my bets at the Local VW Specialist I use with my Fan Fault and as soon as i said the Problems they said it was just the SMALL fan that was the problem not the other, I said its both, described the pulsing and lack of slow speed when the aircon was on, they said deffo only the small one, rang warranty and they accepted the £235 bill.
I let them do it and had no hope that it would fix the problem, but it does!!
So it looks like only the small one needs replacing and at £235 fitted thays not too bad!
Both fire up slowly as soon as I press the "snow flake" and stay on, no pulsing just pretty much silence!
Jon
S177 110A Alternator
S176 110A Interior
S164 40A Radiator fan
S163 50A Engine Glow Plugs
S162 50A Coolant Glow Plug Heater
S180 30A Radiator Fan
S179 30A ABS
S178 30A ABS (pump)
hi found the problem to be the nime box itself it seems that the curcuit board had burnt out (10A fuse was ok) through the brown wire. still not sure what caused it to burn out is it a fault with the nime box itself or something else that has caused it to blow. any suggestions ?
