LCR vacum loss
Lodgey180
WoOoOoOsShH
May 3, 2008
1,046
Middlesbrough
www.mootr.co.uk
I have a LCR 210
i took rocker cover and throttle body off for painting
when i have put them back on i seem to have a problem with vacum
my boost gauge is running slow and getting bad chatter from my airfilter.
there doesnt seem to be enough vacum to open the DV?
i also took the FPR off to clean the crap that was on the top of it.
I have checked all the vac pipes to dv fpr and inlet manifold and all seem fine
can anyone help or point me in the right direction
__________________
wild willy
2,323
Wales
I think your problem lies in your throttle body refitting.
Did you refit the gasket.
did you refit the vaccum tube connected to the top of the throttle body.
Is the throttle body hose refitted properly.
I would take the throttle body and rocker cover off and refitt them both and be very careful on how you refit them.
Lodgey180
WoOoOoOsShH
May 3, 2008
1,046
Middlesbrough
www.mootr.co.uk
yes i have a dv 30 a standard one and now a 007p all no good..
the faults i had was
16804 17526 + 17522 which are all to do with the de-cat
17695 + 17608 which is the n249 bypass
17951 + 17580 + 17987 + 16891 which is when my dopey mate turned the ignition on while the throttle body was off
16486 which i had the maf unplugged
18010 which i presume is when i had the battery disconnected
16497 intake air temp sensor which i put a new connector on last night as it was snapped
Lodgey180
WoOoOoOsShH
May 3, 2008
1,046
Middlesbrough
www.mootr.co.uk
problem is now sorted.. it seems that one of my t peices had a restrictor it that has been facing the fpr since i have owned the car.. when i have tidyed up my vac hoses the restrictor faced the DV instead.. cut the restrictor out and all is now fine.. :)
