How many clicks with CC Phase 1?
  • 14
    Votes: 0 0.0%
  • 17
    Votes: 0 0.0%
  • 20
    Votes: 0 0.0%
  • 23
    Votes: 0 0.0%
  • 25+
    Votes: 0 0.0%
  • Total voters
edmong
GHE Tuning
Aug 15, 2007
567
Plymouth, Devon
Please help!
I have had no joy from CC or Forge so hopefully someone out there has the same kinda mods as me and knows how many clicks/tension the Forge Split R is at.
I have not got a boost gauge yet so I do not know what the car is peaking/levelling out at. Any guidance will be great but any negativity regarding the split r can be left in the previous, old threads!:whistle:
Didn't you get an answer from Forge in this thread?
http://www.seatcupra.net/forums/showthread.php?t=215173
The full/semi recirc mode has no bearing on spring tension as far as I am aware.
Personally, I played around with mine alot doing lots of logs and determined that the number of clicks could vary alot (5-10 clicks) without making any noticeable difference to performance. Didn't like the way it was running so got a 007P and it really is much better.
didn't you get an answer from forge in this thread?
the full/semi recirc mode has no bearing on spring tension as far as i am aware.
Personally, i played around with mine alot doing lots of logs and determined that the number of clicks could vary alot (5-10 clicks) without making any noticeable difference to performance. Didn't like the way it was running so got a 007p and it really is much better.
+ 1
Just adjust it till it stops clicking,
And when you fit your boost guage DONT take the feed off the top of the Split-R, They dont like it.
Yep thats it, It might start clicking again when it warms up or after a drive so adjust it again til it stops clicking, once it stops clicking then leave it alone.
Are you useing it in atmos or full recirc mode ???
In atmos when the air is dumped (i have 57i aswell) it seems to make 3 very quick air releases rather than just the one when I had the old valve on, is this norm?
Mayb going to full recirc will be better then.
Have you got it fitted this way round ???
You would think that it looks upside down but this is the way it should sit.
Yeah its fitted right.
Put it full recirc now and taken it for a blast. 12 clicks later and its running like an absolute dream:funk:. Still got the 3 short blasts of air when it dumps though, cant be a prob though can it?
Thanks D.K. Should have just posted here first of all:headhurt:
