Prau187
196
92
Hey people I've got a problem with my engine I've had a oil sump and oil pick up pipe clean out because it was clogged up the I've put all new oil and filter and start the car up suddenly it starts to smoke out the exaust and the and I find a leakage coming from my exaust can any one help what the problem is ???
Check for play in the turbo, if the pickup was blocked I'd be betting on the low oil pressure having killed the turbo seals. Now that the oil pressure is restored, it is too high for the seals to hold back.
Thanks pal ill get that checked out but do u think it might be stem seal valve
Ok I'll get the turbo checked first thanks mate
I agree turbo is the most logical source. Not likely for valve stem seals to go suddenly like that and to such an extent as to have oil dripping from the exhaust.
You don't say diesel or petrol but if diesel be wary of oil getting back into the induction and engine going into perpetual running and not being able to stop it.
It's petrol mate I've just left the car at the garage to get the turbo checked hopefully will get an answer soon if the turbo is gone
