LED tail lights?
NickyJam
FR - gone, not forgotten
Mar 17, 2008
1,645
SW LONDON
the quality is not half bad on the headlights i got, plus the UK stockist had them readily available so no need to ship from anywhere...don't know too much about the rear led lights, however, i had noticed them on the dectane site.
good luck with the rear lights mate
Mar 19, 2010
1,315
Cheers for info. I had a lot of spare money so I thought id buy some but finally im going to have them soon ha
Mar 19, 2010
1,315
got some cable today to swap the bulbs. going to have to wait till it stops pissing it down to fit them. have no access to my garage at moment :( dont worry ill have them done soon haha.
Mar 19, 2010
1,315
Pics
Mar 19, 2010
1,315
plug in and play, just has LHD set up so I need to wire the reverse side to fog and fog to reverse so they light up correctly. Got some cable today
Mar 19, 2010
1,315
Right there 'in'
The side lights went in fine. Wired them up opposites to make reverse light / fog work correctly but when the fogs on ,the right LEDs cut out until turned off and the left LEDs do the same once the reverse comes on... Anyone have a idea why ?
Another problem was the centre lights have a box on the back which I think is making them sit high which puts then out if alignment, might have to shave them down to see if it makes them sit right!!! Apart from a few teething problems the lights look brilliant and suit the car well. I'll post updates as I smooth out the issues
1,315
Ye should fix the little issues and the wiring was a doddle, chocolate blocks and some cable. Might aswell try new things I like to be unique! I'll get them flush and all will be sorted :)
Mar 19, 2010
1,315
dectane have contacted me, apprently the black box which is causing them to "sit high" is a resistor pack that can be unplugged and replugged. Going to fit the light without and fit from the inside. maby they are a good fit afterall!
