Does anyone have links to these leads? I'm getting confused with what I need exactly. I have the alpine HU 235bt as described earlier in thread and a pf mk2 leon with steering controls. I'm really confused.
And that's all I need for steering controls and HU to work in a preface lift 08plate leon cupra? I guess any iPhone to alpine lead will work with a 4
What iphone cable are you referring to? The Alpine unit just has a USB front socket so you can use that with your normal iphone cable or you can stream the audio through bluetooth.
Any USB to iPhone. So will all the steering wheel controls work and is that the correct plug as can't take stereo out to check.
well I've never used my iphone with a cable so I don't know how that'll work, I just stream the audio via bluetooth. I have a 2006 Leon mk2 and they were the cables I used when installing the Alpine 235BT so if that's what you've got you should be fine.
On the steering wheel controls you can volume up/down, change source, skip tracks (not when streaming bluetooth unfortunately but that seems to be a limitation of the alpine) and scan through tracks/search radio stations.
And you don't need a cradle for inside the dash?
Do you mean a fascia to go round the stereo? Or a cable to convert the Seat cables to Alpine?
The Fascia I got from Sere motors on here, cable wise this does the job of converting the alpine to Seat and also the steering controls.
