I've got one and it mates upto a standard cat-back fine as it shrinks to 2.75" just before the flange.Well im hoping that the pipewerx dp n decat will fit onto standard cat back system as I cnt
Afford the cat back system at the mo. If it doesnt then itll have to wait for month or too? Anyone put the
Pipewerx dp and decat onto a standard cat back system. Jeff from pipewerx said that it will fit hes either telling thevtruth or trying his best to make £350..
Huuugee difference when mated up with a decent cat-back system, no idea what it'll sound like with a standard system.Ideal) just down to fitting it now...is there much in difference in sound with dp and decat Then the atandard one? Iv also got a o2 spacer for 2ns sensor I take it ill need to use this?
If they use the same jig on the 3" version as they do the 2.5" which is designed to mate up with standard downpipe I don't see why it shouldn't fit.Hi
Really sorry to bump and old thread.
I've got a pipewerx decat and downpipe and like mentioned above, the decat tapers down to 2.76". Does the flange size vary?
So i'm asking will a 3" cobra cat back system fit straight onto this decat, even though it tapers.. obviously if the flange sizes are the same it will be fine?
