Leon Cupra R25
who.am.i
Leon FR
Jan 23, 2016
392
30
EU
Thats a lot of oil mate :)
IC is going to be stock from this engine?or bigger,because of turbo?
vag familia
who.am.i
Leon FR
Jan 23, 2016
392
30
EU
Have to tell u that u have my respect.i admire your passion on build. Are u mechanic or what?
vag familia
POPOV
Newbie
Jun 25, 2005
581
Sweden
Porsche Cayenne 18Z brakes
Some time ago I fitted Porsche Cayenne 18Z front 6 pot and 4 pot rear calipers. Very pleased with the breaking capacity of these calipers so they are staying.
They where in urgent need of some cleaning, that has now been sorted with some water and soap.
Just need to brake of that rust from the wash away...
y3mqJI8bvsd-feZ6PrUak1t8zMHpbv-rmEH2B9sgOQUHUmGjZXDmlOp2O3CVSjenaG-C2VsKPaTTVUvVF7WST6rO5sQfpGpnspyHF1gNAgibHFyZocrZi894htHZchid7U4zqiS2io9qnDnBtcjzO6593GI4Mo7-C3VkXBKnAHsfnY
y3mofw2lLesH-6dEukPX9j5O17fThPe3YsDn0aZFIGoxVmwJdmq0ncGL6c4isRuohRXUtMobNJ0cKWqswmAUqvRBUlwYMeGEK5UMVJyOO5W23cjGXNHFTlKEgr3tUGpg33_7UxjtzPEyIPyonmkrp54ZN2hX5VznaG-0iIRNDJ39WI
:wave:
POPOV
Newbie
Jun 25, 2005
581
Sweden
BBK bleeding procedure
Initiated the bleeding procedure of my BBK set up. Thought I'll share the correct manual bleeding procedure of 18Z calipers on a Leon 1P.
  • Rear right, outer nipple
  • Rear right, inner nipple
  • Rear left, outer nipple
  • Rear left, inner nipple
  • Front right, outer nipple
  • Front right, inner nipple
  • Front left, outer nipple
  • Front left, inner nipple
:wave:
POPOV
Newbie
Jun 25, 2005
581
Sweden
which parts are needed for this brake swap? any other changes need to be made in the suspension?
Disclaimer! Machining and altering the design of the hubs or calipers is dangerous as the original design is changed.
Thus, this can cause a brake failure and kill you. In no way do I recommend anyone to do this!
As the Cupra has front aluminum hubs you'll need to machine the Caliper mountings and the hubs.
If my memory serves me right, you 'll need to remove 5mm from each as indicated in the picture.
y3mMMPpT-fMnUlmX1cJI4NCD3p5nf-Y8aOHzteRXi3Wz2xdEiooIf9CjoWBfk74d3q4uO1b2X47SCKSaAd54aZbXc4j7q8qOw8gbO0lPYFtp2SC6Tm2_Agom2OIx6mzlxbS52XmM5jJ6CIoLQOOJayZlEjKZ-Gdwtq8MJ-dcnqL0Uo
I've had this set up for two years with no issues so far.
Don't forget that the calipers where designed for a car with far more weight.
If you have steel hubs (not Cupra) the calipers should be a straight fit.
Besides the machining you'll need steel lines, bolts and rotors.
All described very nicely in this thread: http://forums.vwvortex.com/showthread.php?5830375-Brembo-18Z-6-piston-brake-upgrade.-DIY-BBK-write-up.-Big-brakes-for-under-a-grand
For the rear you need adapters, I got this set up:
http://www.ebay.co.uk/itm/VW-GOLF-MK5-GTI-AUDI-A3-S3-SEAT-LEON-CUPRA-SKODA-VRS-PORSCHE-REAR-BRAKE-UPGRADE-/171094302701?hash=item27d603dfed
The adapters are utilizing the OEM rear brakes as parking brakes. That just adds more un-sprung weight so I'm simply driving without the fancy parking brake feature.
My engine acts as a perfect parking brake, I always leave the car in first gear.
:wave:
POPOV
Newbie
Jun 25, 2005
581
Sweden
Return of the engine
At last after supplier mess ups, supplier delays, funeral, injury, workshop delays.
Engine and gearbox are now at home with me :funk:
Let the fun start! Finally I can start to assemble all the pieces I've been collecting for a while.
y3mvTVSLpptEwQwI4q88pOLIVQdkpfmVvyCd2xEY9f_fF3BOmC8lk6fVmaTpFh52RJvzL4FocxQHIOFj31PdKXLQHLFW-e4IoBGxL09uT7kRAkxOJKF6UJjhO9S_ZMZCY5ysLMa7lFvFu4opt_N4q5YR6AfPx8C59-ZkRSba-V-KQ8
y3mRDTYahuvpmWEVvkdJIdJAttZEH7QmFkym18cPSuozPkvE-5BUKa2ImP5fmlWuwifyXmd7LSdcqpJgu3PnY6t3gtJC18Iw9N5_bw0vTJzpXWm9pmsF5XCCYObF_vdBk9MZL0IhmzNkN3aZKUpsjWLICZ6sMSQmmOXNuCs7SpCP0k
:wave:
Beltran
26
Nice!! I'm waiting to see all of this process. I wish you success.
Best regards from Chile!
POPOV
Newbie
Jun 25, 2005
581
Sweden
Turbo fitted
The current focus at this stage is to mount the rear engine accessories as I want to fit the engine into the engine bay.
Thereby the sexy K16 turbo from TTE went on yesterday, lot's of joy at this stage of the Cupra R25 project.
y3mi35EjpK0U5s5pcRuJ4lWiiXY5R8vZAb8hflecub71uUpcoXIowvYwZ5g3FPTWe_xRBqTDc_Md8zyhwtar9JMdKkwcunK1f74JEJZ_7GkORSYNMkywhc-pA5eaG1NMw7OrUg5h3HKqtJW7vLSaaY9uaTnCosck93hhyZyfXtYXSs
New custom steel oil return, oil feed and coolant feed lines will be made. I already have a custom set up of lines that will fit but they are not steel lines.
Some of you may spot the EGT sensor, lovely feature that unfortunately was removed by Audi.
According to Elsa it was available until 2011.05 but the AUDI spare part catalog states 2010.08. My ECU is a early 2010 unit so I'm lucky as it will support the EGT sensor input.
:wave:
POPOV
Newbie
Jun 25, 2005
581
Sweden
Gearbox and clutch fitted
Further progress has been done during this week, 02Q gearbox and clutch is now fitted. I'm planning on getting the 5 pot into the engine bay the coming up Monday.
Hopefully no surprises will stop me at this phase but you never know what issue will arise at any moment when doing this type swaps.
y3mGegXPBWmeNtpGQc2hzMLmOoYjPbPRCl_Vp4laWL5Zr_6iEOZPbPJ0q1LPRm3fT_fYqN4435rsXZqJpWuYdGw7nfebeVBjU7GVvOagsuZu2x-2YX5FJLT7FIHzLwxDyWReLpqPC-Z5y7LwQA8kSIJoNmQFOTHttwsDAxgAjIOUDw
Spot the lovely 4th gear support!
y3m7Ei25wiq7dVyeFyTxDs-suh1QAwQ0PcsPUnHlZrfIKTiFxi2BZbVnNjxjdQ16RCAw8KVlHHIpi6qcX6M6eY4Kw3vMM5wgC_FA0JxFKYcqVSDiNwQjZwwiysGOlGa4IERL3brf0FLO8xqf0mHebFO4zNLCaI3cSwWQ-BUMVArVU0
Earlier in this thread there was some doubts of what and how the gearbox housing had to be modified to fit.
Now that is clear to me, minor grinding of the upper part of the gearbox was needed.
Image borrowed.
y3mQ1aMeqaIix8wtomNGFE_OM3zLArIgUAU74Y7wbFIz4ddrKBTw4tw39vZZ2eLoVZlAvpbEcEVroXef0VGqfEtSZ_iNwTXxGrBliN_ZyAP3-N3oHhWnyBi_LA-Zhbkushw74a6JVlDlRPQnX_YjWQNbvD2QTjQQIWHgPLap2CJSmw
:wave:
POPOV
Newbie
Jun 25, 2005
581
Sweden
Engine is in!
With almost no struggle the engine popped in and aligned nicely with the former engine mount fitting locations.
VAG's platform production process is really something...
To my knowledge this swap contains many "Firsts" :
  • First Leon 2.5 TFSI swap
  • First 2.5 NA engine block and 2.5 TFSI cylinder head build
  • First 2.5 TFSI and 02Q gearbox build
y3mshBElYK4a-jm8VedaAENyAWSX5BYanadzAz6plESwDmBJmwTK6Ssuc8hp3Z8KeBN6VG7JTaRbqvrvSaYVGLfwo4BPvOHc-L3jhzsDj0cROuJ-ulA5YhE6VD125NYm93mL0Xyykv9iDVHPXIwTfHdp7EukmJO4qILQM20WCtus28
y3mEDPe6PvtMB53bnM8LsKjUdnvugnWFg0Poia9vzx6gi9GN5TdrPx2Zk71UrQcqZPT8OvWnZ7HOWyPbMJwf7APMo42mLHXYr7iEza2zO1lkZENL6mAb7_BEt7Jnoeieyq7w6i26VrV_d7gBSJOkLJ5l0vJNiHL6Tx_2y2V0fudsWw
y3mJ-Okce9-EpCRtcB-eIjp7E3bOrEZimkVdklc01xkioa1pVRIkXkxZq6p3nZnaZA3Nsy3oV8SYTzZldZSV6amSZJ_x85cgpZbBzB6WNfr7Ujb5y9OiE_rZHL4XNOaud1PLKzmsCF6-alyPTz_uUgfnAjLXXK_0U-SBnvIK5zzQyI
:wave:
SWANSWAY CUPRA Dealership
