What happened since last?
Well first of all the turbo did not arrive as hope, so ended up in the wife’s Golf GTE for the Italy trip
Anyway, while in Italy the turbo finally arrived and the garage assembled everything so it was ready on Wednesday.
They had performed the different procedures in connection with the first start of a brand new engine and started it/had it running for a few minutes, but it was still at the lift in the workshop when I got there. I ended up taking it for it’s first test run myself and everything seemed to work perfectly.
So how is it? Well, I have not been above 0.4-0.5 in boost as the engine has to be broken in so the experience so far is only representing a fraction of the full experience, but:
- initially I was a bit nervous about the potential noise and shaking from the uprated engine mounts. At first it was quite heavy, nothing like Powerflex blackline, but present and something that would not have been feasible for the family run. Within the first 50 km most of the vibrations and noise is gone, leaving an increased throttle response and stiffness to the drivetrain with only limited vibrations etc when at a stand still. A perfect compromise and highly recommendable.
- the sound is fantastic. The standard Cupra ST exhaust is way to quite in my opinion, but I need the car for long distance driving and the daily commute, which is mostly spend having calls with clients, so it had to be relatively muted still in everyday driving/highway cruising. I can only recommend the resonated Milltek system in that respect. You can hear it now and it have made the car come alive, but in cruising etc. it is not intrusive at all. I did not expect to be able to hear the turbo, with the full carbon intake mounted, but you can. There is a distinct turbo spool whistle and pressure dump sounds, but not something the wife notice.
- performance wise I really do not know yet, other than it is apparent that the turbo kicks in a few hundred rpm’s higher up the rev range and that there is something significantly different from stock. The spool is much faster and the performance with just a fraction of boost leaves most family cars struggling to keep up.
- I was running stock dsg software with the Revo stage 1 tune. I got the tcu stage 3 software installed yesterday and that is really impressive. It improved shifting characteristics significantly, smoother, faster and more responsive so I regret not getting that installed earlier on..
I will keep you updated on the experience
