leon cupra - winter protection
jake
I AV MOSTLY BEEN BEATING
Feb 2, 2003
2,666
rochdale
if i won the lottery maybe chris haha
got the car on the ramp at dinner to have a look at the caliper, it was seized, very seized :(
exchange unit ordered with pads :)
caliper taken off and cleaned the area, here you can see my tricky dent
IMAG0162 by cuprajake1, on Flickr
this shows you how hot the caliper has been, the paint is destroyed, the rest of the calipers look like new
IMAG0165 by cuprajake1, on Flickr
the pads on the good side did have alot of meat left, but the seized side were down quite a bit,
old vs new
IMAG0172 by cuprajake1, on Flickr
and the shiney new caliper
IMAG0167 by cuprajake1, on Flickr
job done
oh and a taster of the wheels, not orignal but i like them, i think
teamdynamics by cuprajake1, on Flickr
jake
Feb 2, 2003
2,666
rochdale
yeah been looking at so many pics over on scn re the sportlines, but decided on the coils, there both going to ride simular tbh, went for the joms on the recommendation the ride a little better, as the arb wont be getting changed im not too worried about that,
gave the car a wash, used up my last bit of snow foam, totally crap stuff but makes the car look epic, ummmm white
IMAG0209 by cuprajake1, on Flickr
jake
jake
Feb 2, 2003
2,666
rochdale
tried this today, and kind of failed,
the strut has to fix into the ball but its on too much of an angle for this to work so i modified the way its works and went the oem solution
i still used the plates, 20x50mm, welded the nut on the back,
how ever i went through the hinge
heres the hole
IMAG0223 by cuprajake1, on Flickr
after that to allow the strut to come down you have to trim this piece
IMAG0225 by cuprajake1, on Flickr
remove it
IMAG0227 by cuprajake1, on Flickr
cut in half
IMAG0228 by cuprajake1, on Flickr
install upside down
IMAG0218 by cuprajake1, on Flickr
i also trimmed the rubber 1/2"
this is it fitted up, no more bonnet stay :D
IMAG0215 by cuprajake1, on Flickr
IMAG0232 by cuprajake1, on Flickr
IMAG0220 by cuprajake1, on Flickr
IMAG0221 by cuprajake1, on Flickr
the struts are off an audi a4 13" long, while they hold the bonnet they dont lift it, so i need something stronger which i can have made by a company :)
jake
Feb 2, 2003
2,666
rochdale
fitted the joms today with the help of chris.*
i wound them leaving about an inch of thread and tbh the car looks like standard ride height. i still need to adjust everything but surely that cant be right. i know they should settle but about 2" lol*
jake
Feb 2, 2003
2,666
rochdale
Figured it out,
me lol wrong instilation, ive never done a mk5 chassis, only mk4 now on a mk4 the tab locates the bolt, obs not on the mk5
this tab\/
STRUT by cuprajake1, on Flickr
goes below the bolt, thing is i rand dpm and h said grind the middle
jake
Feb 2, 2003
2,666
rochdale
Changed the dv today to the revised g version. Tbh the c was immaculate so perhaps a waste of £30. Time will tell. Car feels no different haha
Wheels are due in Monday, I'm then going to paint them in a custom anthracite/xirrilic mix.
I will need rear camber, luckily I have a hunter so can set it up haha
More work continues on the reverse camera badge, I now have all my bits bar camera due to a cockup at hids4u.
This will be one cool mod
jake
Feb 2, 2003
2,666
rochdale
started work on the badge.*
Just need a few little bits that I got today and some wiring and she's good to go.*
Wrong camera was sent so that should be here Monday also, then it's a case of wiring it to the factory rns510 via an adaptor.*
Jake
