Very nice!! Good use of pictures too!! Very detailed
Black Leon Fr, stage 1, DSG stage 1, carbon grill, BTCC spoiler.
Are there any advantages/disadvantages of the bcs over a milltek or eurojet????
Thanks!
I can't tell....have never had Miltek or Eurojet CatBack, my down pipe is an Eurojet and can tell It very nice built...high quality.
I choose BCS because the EXCELLENT service from Nigel, the price and the lead time.
on the rears, it looks like a small and then large spacer stuck together?
I can only see one.
It's the H&R spacers, DR-system since they are not bolted (believe 20 mm is max).
You can also see the part no. Which is always stamped on the spacer:whistle:
Theoretically he will run ET 31 with his 7,5x18" rims.
Robert
How much is a cat back bcs I still haven't changed mine yet?!
I can only see one.
Robert
Right, Robert...It is only one H&R 20 m.m. spacer..
I'm in love with it already :D
Hey there Mexicano,
I am liking all the work you have done to your car so far.
I currently have a modified volant intake for my car and it works really well but tends to be quite noisy. (Also have the forge diverter valve installed). When i drive my car it sounds like darth vader and a turkey are having a fight in my engine bay.
I was just wondering what the forge intake is like? Do you also get a lot of noise compare to stock intake? and do you also have either a pop off or diverter valve whose noise gets amplified due to the intake?
thanks good luck with the k04 conversion.
M001.
Hey there Mexicano,
M001.
Hi There!
I like the sound of my Forge Intake...is louder than stock but not too much unless You go full throttle, Forge valve is noisy..I have the Atmospheric diverted valve.
Regards
Hi There!
Regards
ok, thanks.
sounds like its quite similar to mine except your intake probably makes a little less noise.
I might look into getting the forge intake one day.
thanks for the info.
