Whats up Mexicano
Now, the FORGE Turbo Pipes:
This is how they came from FORGE....
I didn't like them in aluminium, so I powder coated in black finish:
Underneath cover removal:
You can see the "flatened" plastic pipes:
Compare the pipes:
Let's do this....
Front pipe removal:
Did you order this from the guy in San Luis Potosi you told me? Or direct from England?
Do you have the exact description or part numbers of those Turbo Pipes?
Please help me, since the first time I opened the hood I saw those horrible flattened pipes and I knew they were :censored:
Saludos!!!
This nice item, It is a complete solution for lifting your VW/Audi without crushing the rocker panels...the kit includes the OEM jack pads that fit into the body and ECS Tuning custom designed jack pad adapter:
Just remove the "caps" from body:
Insert the new pads:
And You are done!
Remove the covers from the front:
Install the new Pads:
And I made my "own fix" to re-install the covers:
Where did you get this kit from and how much? Also where did you get the clock rings from?
Saludos!!!
I dont remeber the part number for those turbo pipes..just ask Tom(The guy from San Luis Potosí) he knows what to order.
Regards
Forgot to show You how It will look...LOW...this a quick tease from the front when they finished the front end:
Now a few more pics from the front suspenssion:
Few more...
I don't like these arms....Do someone know if there are some kind of stroger/better aftermarket arms?
It was hard to "press" the bushes!
NEW CHALLENGES-REAR BRAKES....This remainds me about Jim Rohn:
Don't wish It was easier, wish You were better. Don't wish for less problems;wish for more skills. Don't wish for less challenges; wish for more wisdom.
Rear bushings...the Rear Trailing Arm Bushings are WhiteLine the rest are Power Flex Black Series Poly bushings
I'm not going to use these Upper Rear Control Arms anymore but I already had the bushes:
Love all yours mods, but gotta say you must have some money to be able to keep doing them all. I wish I had the same to spend making mine as good
Forget the money! It's rude to mention how much lol.
That must be in top 3 handling Leon's, it seems I'm working threw the same list, what's next?
Thanks :D Money is not all....I would say Love, Passion...I have been doing mods to this car for 20 months now...and still there is a couple of mods I want to do.
Regards
