Right had the car plugged in...Heres the LIST!! of codes!
Anyone???
016891 - idle control module - RPM higher than expected
016885 - vehicle speed sensor
016804 - Catalyst System Efficiency Below (Decat)
017705 - Turbo/Supercharger connector - throttle valve
017947 - Clutch pedal switch F36 inconsistant Signal.
So... to refresh everyones minds. The car is cutting out when i am slowing down to stop. When approaching roundabouts, junctions, obstructions in the road...etc i slow down using the gears/brakes and when i put my foot on the clutch for the final time doing say 15/20 mph and stop the car simply cuts out.
I really need some of you clever people to give me some advice here as I dont want to replace each part to rectify my
problem.
Can i test any of the parts relating to the codes? If so how?
Cheers guys
Barney
