lizzard 1
hi having probzzzz with left to right adjustment of front lights, up and down ok .its a pain to get the light to shine in the right place. is there a way to adjust or are they preeeeee set at makers. been out in fooooogy nights to try to seee the beam. its shines a bit,,, well a big bit to the left , itg great for left corners ,, but shi* for straight or right corners.
Think there's "star" bolts in the top of the light assembly, that you can get at thru access holes in the slam plate.
Not sure what does what, but best bet is to get yourself to a friendly MOT station, and make adjustments while infront of the beam pattern thingy they use.
PS - might what to check your "E" key, think it's a little sticky...
hi yes i have given these a turn , but they adjust the up / down. will give it a look at again in daylight. thanks
