lightened flywheel
Noticed how well your car engine breaks? Well say bye bye to that! Its not going to help going up hills either. People say it does make a big differance on ABF's. The price would be dependant on whether you can take it off your self. Probably wouldnt be over 70 quid to actually get it done by someone with a prescion milling machine. Im not too sure about the balancing of it though.
dave has just had it done. have a search. He said he couldnt notice becuase of the change in ratios done at the same time.
Jamin
ibizacupra88
cupra dean
Apr 8, 2007
123
weymouth
i could fit it my self but if it is more bad than good might keep my money for something else.
any performance mods to recomend?
Dave_R
Save a Sheep...Buy Brembo
Sep 20, 2004
3,666
South Wales
Well at Volksfest sunday I finally met Greg.... rev'ed my car and then he rev'ed his, ever notice how long it takes to come back down to idle???
Well half that time!
You won't really loose torque as the standard flywheel is 22lbs and with it lightened it's 11.8lbs so even with it lightened it's still heavy compared to the 8v flywheel that weights 5. (something) lbs standard!
If I didn't have the gearbox ratio's at the same time I could give you more infor but the car does pick up very well!
Here's a pic of the standard 16v flywheel
And after it's lightened
I would recommend it!!!
Icecavern
6,214
Berkshire, UK
www.icecavern.com
How much does it cost to have that done?
Dave_R
Sep 20, 2004
3,666
South Wales
Think it's between £70-£80. I have felt the weight of an 8v flywheel and its sooooo much lighter than the 16v's.
8v your own compression plate is needed to balance the flywheel but with the 16v it can be balance on it's own to "zero"
And I do recommend changing the clutch, I had a spare clutch kit in my room but decided not to change it as the clutch was only 9months old.... after a day of driving my thrust bearing went to had to remove the gearbox again.
Search for 3.94 final drive and there's part numbers in there of bolts that I changed when I removed the g'box... driveshaft bolts, seals, flywheel bolts & compression plate bolts....etc
gregclarks
Trying to Resist ARBs
May 31, 2006
314
the heavy clutch means you can hit the redline again quickly - it is an auto rev maintaining device! people should pay more for one of those! jesus... am i clutchin at straws??
Dave's Cupra is a slag, its an abolute rally slag of a car, horrible colour too. (well jealous - it screams!)
Dave_R
Sep 20, 2004
3,666
South Wales
have you had any problems with it as i heard it is badly weakens them if they are turned down
Can't see how because you not changing the properites of the material (ie... heat treating it). The bloke that done mind has done loads of flyhweel for the boys on cgti and he haven't had any back broken!
