Lighting set up
BenH1993
88
10
Is their any reason why the coming home lights seem to be brighter than my dipped lights?
May be a rather stupid question to someone with any knowledge
Sent from my SM-G975F using Tapatalk
The Daily Meme
Insta: @thatredcupra
Jan 3, 2018
912
466
Cambridge
Yes, the LED signature lights, when your dipped beam is on, are dimmed to the same level as when you indicate on DRL's. However, when coming home lights are on, there is no dimming.
EDIT: headlights themselves should be the same
KXL
KXL
Dec 15, 2016
1,581
197
London, UK
Ahh, yes it's still the same these FL these days. DLR has 2 modes, on 0 (on switch) it's on 100% brightness, on sidelights, it's perhaps 30-40% brightness, on regular dipped beam, it's also 30-40% brightness + dipped beam. On coming home, the dipped beam are on, and the DRL are on 100% brightness.
daniel_ley
97
35
Dudley
Interestingly, with the Facelift, when the light switch is set to sidelights and the ignition is on, they still remain at 100% brightness and don't dim. They only dim when the ignition is switched off (and still set to sidelight position), or when the headlights are on.
