davemotor
12,507
9
Belfast UK
Can anyone tell me how to operate the 'coming home' function which is meant to leave the headlamps on for a while after parking, and turn them on when getting back to the car and unlocking?
sounds bad asking as a dealer :redface: but asking salesmen is like asking the wall
handbooks not terribly clear . . . . . .
Err.... turn car off ... leave headlights on dipped (or full / auto) ... remove key from ignition, open door .. close door.... lock car.... wait, lights will go off.
If you have bluetooth, then you can go into the menu and adjust the time from 5 seconds to several mins.
will try that. and do the lights come back on when you remote unlock?
Nope :no:
Unless you have "auto" lights, then they might (if its dark).
Lights will however come on as soon as you twist the key in the ignition to postion2 (i.e. the one before it starts).
Nope :no:
sod that then :(
i must have misread the books - i thought they came back on
oh well, if SEAT is reading this then that could be an idea :whistle:
pity they dont do the coming home function with the foglamps like Audi
See my vag-com guide for enabling leaving home lights. Its a bit hit and miss though. Im sure you can code a similar way through your VAS?
sussed it yet dave?
without looking i think its in the convenience menu on the larger (bluetooth) mfd.
lights 'leaving home' i think is also an option.
sussed it yet dave?
was full of good intentions to try it, havent had a chance :(
thanks for the advice, may need a play on our SEAT computer if Vagcom is needed to enable it.
sussed it yet dave?
Thanks Chris its exactly where you said. I remember playing around in there when I got the car, after 15 months I actually had to get the books out as I forgot how to get into the MFD menu :redface::headhurt:
Coming home function perfect, the 'leaving home' where the lights come back on when unlocking must be a feature with the auto-lights only :(
Thanks for the help!
Leaving home can be enabled with VAG Com :)
