limp mode - charge pressure control positive deviation
gregorcupra
254
Paisley
Made some really good prgress tonight :) :)
Went around and clamped up absolutley every pipe with new clamps , and changed one last vacum hose for silicone.
Went out in the car and the boost is still not consistent , however it did hit 18psi for a short while and bloody hell it was quality ! :)
The car then juddered and I lost all boost , so back home. Went around all the intercooler pipes again and tightened them up. Back out in the car and the ic hose that joins to the existing pipework in the centre of the car popped off. Now I think I have made a bit of a schoolboy error with this as I left the rubber sleeve on the plastic pipe to clamp the new intercooler pipework to , so essentially I had a rubber to rubber connection :S
Really chuffed but still getting the following codes
17963
17965
sparkie1984
sparky
Aug 17, 2008
1,005
i said it would be a hose! :)
thats where mine was blowing off :) infact i know another couple of people whos does it in the same place too, must be a weak point! im getting some clips and im gonna go round the whole system and replace and tighten them all right up!
edit: i was obviously misinformed about the clips then!
gregorcupra
254
Paisley
Yeah mate cheers for your help still a bit off sorting it though.
Do you have any photos of the way yours is joined in this area ?
I think Ive done it wrong
sparkie1984
sparky
Aug 17, 2008
1,005
when it blew off:
back on:
sparkie1984
sparky
Aug 17, 2008
1,005
wtf?!?!?!?!?!?
lol, that is prob your problem then dude :) well lets hope so ay!
i was missing one length of the rod too! luckily i use it in my day job so had some!
get a pic up of your setup dude!
gregorcupra
254
Paisley
Well basically where you have inserted the alloy pipe , I have put the blue bend straight in there , hence it blowing !
Do you know the size of the alloy pipe and also the type and size of bend that is and Ill get some ordered ?
Cheers mate
sparkie1984
sparky
Aug 17, 2008
1,005
er, not too sure mate, it came in the kit though, everything apart form the new jubilee on there came in that kit, also surely it must be sitting tight on the engine if theres no alloy pipe? which is probably not helping.
danny lad, yeah same as, scared the shite outta me!
sparkie1984
sparky
Aug 17, 2008
1,005
i had to keep pulling over and slipping it back on, the jubilee was nowhere to be seen!! :)
only problem was it is all pitch black country roads so i was bricking it someone would come round the bend too fast and take me out! but i didnt want to call the aa out over it!
